Bosch VeroProfessional 300 TCA7301 - water on waste deposit, not in cup
    • Bosch VeroProfessional 300 TCA7301 - water on waste deposit, not in cup
      Hersteller: Bosch | Typ-/Modell: VeroProfessional 300 TCA7301 | ca. Baujahr: 2016
      Hello, My machine tca7301 is runing the water for the deposit not to the cup, already replace the ceramic valve and the seal for the brewing unit, but sitll water not going for the cup... need help please
    • Put the faceplate of the water bowl out . Then put a screwdriver into the slot of the water bowl switch at the """Front plane"" of your coffee maker, to simulate the switch is on, you understand? Now turn the coffee maker on and try to locate where the water comes out.....I have no picture at the moment.
