Hersteller: DeLonghi | Typ-/Modell: ESAM 4500 Magnifica | ca. Baujahr: 2009
Hi,
The diffuser was not going up anymore. After resetting etc it tries to go to original position but it seems that the bottom thread of the bolt and the screw are weared. Does anyone recognise this after 12.000 cups of coffee ?
Is it possible to only order the transmission kit without the motor. Or even only the screw thread and the nut screwed on it ?
You can see from the picture that it is possible to unmount it, so reversed mounting should also be possible
I am only thinking that maybe the thread is not weared too much but all the pollution on the thread caused the problem. Doe you think after cleaning all and putting normal grease on it it can work again ? What kind of grease should I use for this part ?
Ab
Hi,
Ab
