Hersteller: Jura | Typ-/Modell: GIGA X8c (G2) | ca. Baujahr: 2018
Project finished but many questions ...
Machine is working great, very silent compared to the 1st generation.
One les pump and thermoblock, extra ceramic valve instead of the selenoid block.
Just a remark on use, touchscreen is complete shite, super sensitive not to mention the way they did the interface is also nothing to write home about.
Q1: (this one I will answer)
Who came up with the idea to hide power button under the flap by the scrolling wheel should be fired
Most idiotic design ever since to lift the stupid flap without long fingernails is borderline impossible.
Q2:
Anyone managed to find solution to use the g1 style grate with the g2 redesigned dredge drawer? I'm considering ordering the old style kit since the new one with additional plastic piece in the front sucks!
Q3:
How do I modify beverage settings for the rest of the drinks that are not on those 2 front pages? I can't figure this out. If I go to the beverage settings you can only pic from those 2 pages not from the scroll dial.
Q4:
Strangely enough the machine will give you warning to clean the frother but will not rinse it after certain period of time on its own, I find it strange since g1 has this option and you can enable or disable it.
Thanks folks!
Q2:
Q3:
Q4:
Thanks folks!
