Jura ENA 9 - Disassemble the water valve opener
    • Jura ENA 9 - Water valve opener disassembly
      Hersteller: Jura | Typ-/Modell: ENA 9 | ca. Baujahr: 2013
      Hello everyone,
      1/ Does anyone know how to properly remove the valve opener for water please?
      2/ Is it possible to put a new generation mill in place of the original mill?
      I'm not talking about the complete grinder.
      Will the grinding quality be improved?
      Thank you in advance,
      Sincerely, Amine
      Sincerely, Amine
    • Hello.
      Which valve opener do you mean, the one in the base of the machine or the valve in the tank itself?
      To be able to say anything about a possible grinder replacement, you first need to determine whether
      your machine requires or has a standard grinder or an Aroma+ grinder.
      Depending on the version and age of the machine, both are possible with the ENA9.
      And it is a ENA9 and not a ENA9 Micro?
      The year of manufacture also allows for both possibilities - but in the case of the ENA9, the Aroma+
      version is probably more likely.
    • Hi,
      Thank you BS, I finally found how to do it.
      It was the one in the base of the machine.
      It’s a 2013 ENA 9 One Touch with a ME-005 grinder.
      I found this grinder for my machine and im wondering how to place it :
      komtra.de/jura-ersatzteile/jur…on-kranz-extra-leise.html
      How do I know the correct setting ?
      Do I just have to place it and play with the 3 settings of grinding on the upper of the machine?
      Sincerely, Amine
      Sincerely, Amine
      A brand new grinder comes pre-adjusted from the factory. Simply install it in the marked position and insert the adjustment ring into the middle position.
      What the hell is this deleting of the first post in the thread, means nobody with a similar question can find it, and my answer is left hanging withou any sense. Fix it. The forum is intended to help also others in the future and is not just a personal complaint box.
    • I'm sorry I wanted to change the title but before that I accidentally deleted my question, then changed the title…
      Unfortunately, I do not have the possibility to put my question back in place however, it included the correct disassembly of the water supply valve opener in the base of the machine.
      My second question was about placing a new generation mill in place of an old one.
      I have placed your answers to my questions in the following.
      Sorry for this mistake,
      Sincerely, Amine
      Sincerely, Amine
    • Hello,
      I have restored the post :thumbup:
      On the photos found on the site's product sheet, I don't see a marked position on the crown precisely.
      I'm going to order one today but I'm a little afraid of not having this marked information.
      The delivered grinder should have a marking – if not, we'll investigate further...
      If the grinding cone is not destroyed and the mill and motor still function, this would also suffice
      (but ONLY THIS ONE and nothing else and NO V5 grinding stones).
    • :thumbup:
      The grinding cone is not in good condition, it has had some splinters.
      I was going to place an order when I saw that there is a new version for the grinding unit for 10€ more, but sold without crown.
      I just have to get the crown from the other grinder and maybe the ball, right?
      komtra.de/jura-ersatzteile/jur…ne-kranz-extra-leise.html
      What is it worth compared to the other ?
      Is it better?
      Sincerely, Amine
      Sincerely, Amine
    • Hello BS,
      I am getting back to you regarding this ENA 9.
      I have received the grinder; the marking is present, and I was able to install it.
      However, once the machine is turned on, it emits a few audible beeps and displays Error 8.
      I noticed that one of the plastic mounting tabs on the encoder was broken; I replaced it with another one, but the problem persists.
      The BG does not turn at all—except for a split second when I push it manually.
      I do not think it is an electronic issue, since it did work (for that split second) when I pushed it manually.
      Homever, when I reinstalled the brew unit, I was careful to set it to the home position.
      I should also mention that the gear on the unit's motor has some very slight, minor damage in places.
      That might help in understanding the problem.
      I have a gear in good condition from an A1 that I can use as a replacement.
      Should I position the gear wheel on the opposite side to force a reset ?
      Edit: here is a video of the machine and at the end, the encoder that was broken.
      youtube.com/shorts/uEyxzWYL2f0?is=CryNY-lTmzo7v8xE
      Sincerely, Amine
      Sincerely, Amine
    • Hello.
      The error in the video has nothing to do with the encoder. If the brewing unit moves freely, or better isn't completely blocked, the drive motor isn't receiving power or is defective. Check the transformer (under the water tank) and the wiring (I don't have an ENA 9, so I can't provide a picture of the correct wiring). If the transformer, cables, and motor are all okay, then there's an electronics fault. But I think I can hear the relay that controls the motor clicking. This speaks more against a control defect - but who knows...
      The A1 motor should work, but the A1's gear is smaller and would need to be swapped with the ENA drive.
    • Indeed, the relay controlling the motor click is activating. Yes.
      When I push the brew group wheel with my fingers while the machine is running, it turns slightly for a fraction of a second.
      Does this mean the motor is working normally but isn't receiving power? I don't understand.
      What’s surprising is that the machine was working before I opened it, and at no point did I touch or even look at the transformer, the BG motor, etc.
      I’ll check the components you mentioned.
      Thanks, BS.
      Sincerely, Amine
      Sincerely, Amine
    • Hello BS,
      I checked everything you mentioned with a friend, and it turned out the problem was with one of the motor connections on the unit; the stainless steel clamp had come slightly loose from the wire.
      After tightening it a bit with pliers, the machine started up properly.
      The machine makes much better coffee with this new grinder; I followed your advice regarding its positioning.
      Thanks again, Black Sheep!
      Best regards, Amine
      Sincerely, Amine
