Hersteller: Jura | Typ-/Modell: J80 Impressa | ca. Baujahr: 2018
Hello, This part is from a Jura J80. Not sure where it goes or what it is. I looked at the drawings and don't see this part there either. Any help is greatly appreciated.
EDIT: A little more context here. I was working on the machine, so it was opened up. I found this piece laying on my bench near the ceramic valve and the drainage valve solenoid, both of which had been removed and reinstalled. The piece is about 2-3 cm long.Not sure if this helps.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von MrFolgers ()
