Melitta CI E970-101 Caffeo - Confirm the part numbers needed to replace the brew group, drain valve, and O-rings.
    • Melitta CI E970-101 Caffeo - Confirm the part numbers needed to replace the brew group, drain valve, and O-rings.
      Hersteller: Melitta | Typ-/Modell: CI E970-101 Caffeo | ca. Baujahr: Unbekannt
      Good afternoon,
      Melitta CI 970-101
      970-1-0E295488803
      Broken coffee brewing group. One of the three springs on the top is broken due to use and coffee buildup from improper maintenance.
      (See photo)
      I need to replace the coffee brewing group.
      ---> Question: Is it correct to buy the "new version" of the coffee brewing group? Art. Number 20104
      I haven't found Art. Number 00607268. Is it also necessary?
      Regarding Art. Number 00607268, is it the same one I already have on the old brewing group, or do I have to order this reference?
      The problem started with a water leak in the drain pan.
      Now "all" the water goes directly into the drain pan: it runs directly and vertically through the brew group, and sometimes, during tests, very little water comes out of the drain valve, only at the end.
      ---> Question: Is it worth replacing the drain valve as well to avoid problems? Art. Number 622540 + O-ring Art. Number 10108 (MVQ) + O-ring Art. Number 10159
      To replace the above components
      ---> Question:
      Do I need to replace any other parts?
      Are there any other O-rings that are recommended for maintenance?
      Thank you in advance.
      Best regards
      Daniel
    • Hello,
      the 20104 is correct and your old 607268 fits on the new brewing unit.
      I replace only broken parts - therefore I am the wrong to ask to do something to avoid problems in the future.
