Hersteller: Siemens | Typ-/Modell: CT636LES1 - Einbau | ca. Baujahr: 2022
Hi,
I have a CT636LES1 which originally had a E3546 error. Replacing the ceramic valve solved the original problem, but unfortunately I didn't checked the brewing unit, it was too dirty and the valve sucked coffee to itself and blocked now.
Does anyone have a working / service manual for the valve? It is 3 turning wheel choosing direction to the water and coffee. I found manual for another model, but I'm not sure if all working on the same logic.
Any help would be appreciated.
Thanks
Hi,
Thanks
