DeLonghi EAM 3100.SB - Magnifica - DeLonghi ECAM 22.110.B – Problem with Water Flow and Descaling
    • DeLonghi EAM 3100.SB - Magnifica - DeLonghi ECAM 22.110.B – Problem with Water Flow and Descaling
      Hersteller: DeLonghi | Typ-/Modell: EAM 3100.SB - Magnifica | ca. Baujahr: 2022
      Hello everyone,
      I have a DeLonghi ECAM 22.110.B (Magnifica S) and recently started experiencing an issue with water flow. I noticed that the water coming out of the spouts seems significantly reduced, and it often takes much longer to brew a cup than it used to. The machine seems to struggle, almost as if it's blocked or clogged somewhere.
      A few days ago, the descaling warning light came on, so I followed the usual descaling procedure using the DeLonghi descaler. Unfortunately, this didn’t resolve the problem, and if anything, it feels like the water flow is still inconsistent afterward.
      I’ve tried running the cleaning cycle multiple times, but there hasn’t been much improvement. There are no error codes showing on the display either, so I’m a bit lost as to what could be causing this issue. I've also checked the water tank to ensure it's positioned correctly and inspected the spouts for any visible clogs, but everything seems fine on the surface.
      I also check this: https://komtra.de/delonghi-ersatzteile/delonghi-ersatzteile-ecam-22.110.b-cappuccino-systemendix But I have not found any solution. Could anyone guide me about this? Has anyone else had this issue before or know what could be causing the reduced water flow? Could this be a pump issue, or might there still be some internal blockage despite the descaling? I’ve heard of people needing to take apart the machine to clean out deeper parts of the water system, but I’m not sure I want to dive into that without a bit more guidance.
      Any advice or suggestions would be greatly appreciated, especially if you’ve had similar experiences with this model. I’m hoping to avoid sending it in for repairs if it's something I can fix myself.
      Thanks in advance for your help!
    • Der DeLonghi Entkalker ist leider nicht so gut. Nimm diesen hier, der ist effektiver und entkalke damit auch über den Kaffeeweg mittels der Spültaste. komtra.de/reinigung-pflege/kom…um-entkalker-1-liter.html
