BlackSheep schrieb:
I fear that the LEDs will simply overheat and not be cooled enough because, in addition to not dissipating heat, they are also in the area of hot water vapor. In other Jura-devices, cup lighting failures are not so common, they last “forever”.
Lifeisfun schrieb:
those are available as well and generally produce more light, and applied over aluminum cooling plate.
