Hersteller: Melitta | Typ-/Modell: CI E970-101 Caffeo | ca. Baujahr: 2019
Hi,
I'm trying to repair this Mellitta Caffeo Ci (E970-101). The machine no longer heats water and milk to the temprature that it once did.
I have checked internally the pipes for blockages and cleaned them with citric acid.
With the water in the tank at 18.6C when 'hot water' is selected the output water is 78.8C
I have an identical heater and have swapped it together with a different NTC thermistor but the results are essentially the same.
Does anyone have an idea of what I can test next?
Many thanks.
Neville Thannhauser
Southampton, UK
Hi,
Many thanks.
Neville Thannhauser
Southampton, UK
