Hersteller: DeLonghi | Typ-/Modell: ECAM 350.35.W - Dinamica | ca. Baujahr: 2019
Hello everyone,
I have a Delonghi ECAM 350.35W that does not dispense water during the rinse cycle and coffee during a coffee cycle.
I have tested the pump (by powering it directly) and it works well with good flow through the heater and up to the point where it enters the top of the brew group.
Water flows into the upper brew group and exits via the overflow chamber, which is on the left as you face the machine.
The steam outlet, controlled by a solenoid valve, works perfectly.
I have checked each tube and they are free of clogs.
I have removed the lower brew group which moves up/down and cleaned every part of it and replaced the 2 large o-rings - as well as the single large matching o-ring on the top part of the brew group.
Each micro switch has also been tested OK.
Any ideas?
Thanks very much.
Hello everyone,
Any ideas?
Thanks very much.
