Hersteller: Jura | Typ-/Modell: Z5 (G2) Impressa | ca. Baujahr: Unbekannt
My Z5 project is almost done but I have problem with the "one touch" cappuccino, it's not so one touch here ...
The coffee is coming from the main spout when brewing.
First I thought the solenoide does not activate, but it does (I see it extended), and it also works when rinsing the unit manually, except left is right and right is left
Brewing Espresso or Coffee it uses correctly the main spout.
Where should I start troubleshooting this?
I really miss all the Saeco hidden menus where you can activate individual features)
Also, since I get the forum translated by default to English, it is better for you folks if I Google translate my post and post it in German
or English is fine?
thanks
.Brewing Espresso or Coffee it uses correctly the main spout.
or English is fine?
thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von Lifeisfun ()
