Jura A1 - coffee does not run out
    • Jura A1 - coffee does not run out
      Hersteller: Jura | Typ-/Modell: A1 | ca. Baujahr: 2018
      Hello.
      I have problem with Jura A1, you can see on video, when I'm turning off, the water flows slower and slower until stops. This happens when I make coffee, but not always. Coffee goes out normally, then in drops and than it stops. Jura blinks coffee beans as error. I press it, fills with water. I make another coffee, even a drop doesn't come out. Third time it goes ok, for example. I've done scale cleaning. After I clean with tablet for coffee department, Jura works ok few days. Is it problem in brewing unit? Does it need to be disassembled and cleaned? It's 2yrs old, maybe 2..3 coffees a day... Regards!
    • Hi,
      it looks like the metal-screen ob the brewing-unit is
      blocked with too fine coffee-powder.
      Try to clean the metalscreen und adjust your grinder
      more coarse.
