Jura ENA 8 - small plastic object dropped into the powder chute for ground coffee
    • Jura ENA 8 - small plastic object dropped into the powder chute for ground coffee
      Hersteller: Jura | Typ-/Modell: Bitte auswählen... ENA 8 | ca. Baujahr: 2018
      I was operating the cleaning cycle. It asked for the cleaning tablet, and I accidentally dropped the small protective cover from the dual spout into the powder chute for ground coffee. I cannot see how to get the object back out.
      I do not want to continue the cleaning cycle and risk damaging the machine.
      Do you have any recommendations on what to do please?
      Many thanks!
      Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von atomhead ()
    • Normally it comes out after using the rinsing-functon
      or initialisation of the brewing-unit and fall in the
      ground tray.
    • Hello BlackSheep, thank you very much for your suggestion. As it happened, I turned the machine upside down and shook it a little bit. The small plastic cover slid down to the bottom of the chute, where I could see it. I then got wooden skewer and managed to 'scoop' the plastic cover out of the chute. I continued with the cleaning cycle and everything seems fine now.
