Hersteller: Jura | Typ-/Modell: Impressa Z5 | ca. Baujahr: 2012
Sorry, I do not speak German,
Hope you accept Englisch.
My Z5 just give hot water and steam. Rinse / "Spülung" works fine in both pipes but machine will not make coffee..
The ceramic valve is rebuilt and works fine.
The heat exchanger is new
The brewing group is new.
The coffee making process starts but stops before the compression stage.
Not enough water is pressed in to the brewer but electric valve works OK.
No Error codes is displayed
All vales is cleared and seams to work fine
Where can the problem be???
Hope for help
Regards
Olof
Hope for help
Regards
Olof
