Siemens TK68E570 Einbau - No coffee brewed by machine - no error codes - one pipe broken
    • Siemens TK68E570 Einbau - No coffee brewed by machine - no error codes - one pipe broken
      Hersteller: Siemens | Typ-/Modell: TK68E570 Einbau | ca. Baujahr: 2006
      Our TK68E570 worked well for many years. This morning it didn't brew any coffee when pushing the coffee button.
      The bones are grind and water seems to be pumped from the reservoir into the machine.
      I opened the machine and noticed that the pipe between the gray element in the middle and the unit on the side is broken. When I tested the machinewhile it was openend I saw the water coming out.
      As a result I need to replace at least this pipe, but I anticiapte this one is broken due to pressure in the pipe. I welcome your thoughts on the root cause of this issue and if one is able to fix it by themselves. Thansk for your support.
    • Hello,
      this sort of pipes only last a couple of years.
      Its propably a fatigue of material.
      I would change the pipe and look than what
      happens. But be very carefully by assembling
      the new pipe. They are very damageable if
      you are pressing them to much or especially
      depress them to torsion.
